CPU/Mobo Need Help!
Nervz
I need some advice with regards to my upgrades.....
My budget is 30000 for the cpu,mobo and 2gb ram
I intend to use XFX 6600GT 128 DDR3 AGP along with SoundBlaster Audigy 2 Platinum which I already own.
I'm kinda confused with what to buy right now, so guys please help!
Peace
-NervZ
Peace
-NervZ
Corsair Value Select 2GB 400 MHz DDR RAM = Rs. 11500
Asus A8N-SLI Premium Motherboard (Socket 939) = Rs. 10500
AMD Athlon 64 3200+ Processor (Socket 939, Venice, 90nm, L2 Cache: 512 KB) ADA3200BPBOX = Rs. 8000
Total = Rs. 30,000.
Er..Udit, he has mentioned that he wants to use an AGP card. So how would that fit on the A8N-SLI ?
@Nervz, do u own the card or are u going to purchase it now ? As for the processor, get the 3200+ Venice as Udit suggested. As for the board, getting an AGP based board for Skt. 939 is pretty difficult now. Try to get the MSI Neo 2 Platinum or the ASUS A8V Deluxe which should cost u around 6~7 grand. As for the RAM, get the TwinMOS 1GB sticks which would cost u abt 5K each.
BTW, why do u need 2GB of RAM ?
Hi Freaky,
Yeah I already own XFX 6600GT 128 DDR3 AGP card which i intend to use on the new mobo. And bout the 2GB RAM, I need 1GB for my office PC and 1GB for moi gaming Rig.
Any more recommendations guyz...?
Jeez...
AMD Athlon64 3700+ - 17k (Get it from Funky)
ASRock 939Dual SATA2 - 3.5k
Twinmos 1GB x 2 - 9k
TOTAL ~ Rs. 29,500 (And you can donate the rest here :bleh:)
Ok, so then buy 512*4 sticks..
you have 2 different Office and Gaming rigs i guess?...
So you can run 512*2 in each in Dual Channel.
Nothing more can be said. Everything summarised.
Asus A8V / MSI Neo 2
AMD 3200+ / 3000+
Corsair Value Select Dual Channel Packs 512*2 (two of these)
Get Transcend if you cant find Corsair. Try to get Samsung UCC Chips on the Transcend. Dont get the Hynix Chip ones.. DONT. :).
Anish said:
Jeez...
Unavailable. No ETA in India yet.
Corsair Value Select Dual Channel Pack 512*2 (2 of these) = Rs. 12000
ASUS A8V Deluxe Motherboard (Socket 939) = Rs. 5000
AMD Athlon 64 3500+ Processor (Socket 939, Venice, 90nm, L2 Cache: 512 KB) ADA3500BPBOX = Rs. 11000
Total: 28000.
Thank you so much guys for all the suggestions....
I'll soon post the details of my new rig and the pics aswell
Peace
-NervZ
^^Depends on the IC aces. True that corsair generally uses bargain basement ICs on valueselect, however the last few months has seen UCCC ICs on valueselect. Those should clock quite well. But still doesnt justify the 3K premium over twinmos.
