PC Peripherals Help me light up my NZXT sleeved led kit
abid567
Hello guys,
I've received a NZXT led strip from a friend as a gift, Problem is I've lost that molex to 3pin female connector came with it. I went to CTC,Hyderabad and asked in almost every shop but couldn't get it. I found couple of similar connectors in ebay but they cost a bomb.
Is there any other way to light up this strip? or any particular store (online/offline) sells these connectors?
Help me guys I'm struck here
I attached a picture of the board and that's where I supposed to put the power source.
[DOUBLEPOST=1441626683][/DOUBLEPOST]anybody??
I think all you need is a 3 pin fan connector - old ones with 3 pin instead of 4 pins and need to wire up the same. From the looks of it, it is a +12Vcc, Gnd and +5Vcc maybe.[DOUBLEPOST=1441648376][/DOUBLEPOST]It would be useful if you can give us a photo of the back side of the PCB.
thanks for the reply bro
back of the board has nothing written on it...I'll post the pic whenever possible..If I connect a 3pin female to 3pin female and other 3pin goes in motherboard fan slot..will it work?? you got what I'm saying??[DOUBLEPOST=1441732987][/DOUBLEPOST]
thanks for the link..
I'll order it if I run out of all options
Need better clarity pics of the backside. I need to be able see the trace marks from the 3 pin connector.[DOUBLEPOST=1441807743][/DOUBLEPOST]EDIT : Googled for pics of molex to 3 pin. Apparently, one side is +12V and other two are ground.[DOUBLEPOST=1441807965][/DOUBLEPOST]EDIT2 : Googled for NZXT LED cables and got this image from kitguru : http://www.kitguru.net/wp-content/uploads/2010/10/5.jpg
So the right most side is +5V and the centre is GND, with the left most side being unused on the 3 pin connector. it connects to a +5V line.
You can get this done with any simple electrician.
Check ebay ...you can get Molex to fan adapters at approximately 100 Rs a piece ...or else if you have a spare molex to sata adapter ...there is a easy way around ...you can go to any electronics shop and solder the joints for may be 50Rs . If you want i can provide you the pin outs or you may Google it .
Usually the middle pin is Red in colour and gets +12v DC or +5v DC , the first pin is Black or ground and the third pin Yellow for Tachometric Signal .
If you can provide a better pic of the bottom side of the pcb ...i can tell you the exact voltages based on the resistance color codes ..
thank you so much for clarifying vivek
I've this kind of connector lying around...If i cut out that male fan connector and attach a 3pin female from a old fan..will it work?
It's working finally....thanks to subhasis and others
