PC Peripherals USB Audio Port (headphone & mic jack)
Haddock
how good are these USB Audio ports?
http://cgi.ebay.in/USB-Sound-Card-2...6?pt=LH_DefaultDomain_203&hash=item5add7cebc4
Rs.99 :p
do they work without any control panel setup?
My Zebronics Antibiotic front panel audio ports are kind of noisy & mic port doesnt work + in my PC table, its too low for access.
I also own antibiotic cabinet and its front ports give below par performance...
Looking at the description this looks nice..
One of my friend got something similar for 250 bucks .Its not bad sounding at all .Pretty decent.As good / better than some onboard sound cards :p
are spare parts (front panel audio/usb ports) of brands like Cooler Master, GigayByte, NZXt available at SP road? :D
i'm moding my PC table, so i need those things :D
I just got the USB sound card... and trust me it is awesome.. well compared to onboard audio ofcourse..
Infact it is much better than my onboard audio..
Im not sure whether it will work with a 5.1 speaker system tho..
I have A philips shp1900... 350rs had gotten it only for night time..
Gettin a great performance boost coupled with foobar preamp..
Im not sure if this headfone has soundstage or not... but now im definitely getting some.. ;)
If it works for 6 months atleast.. then its a great buy..
Will check with PL21 also later..
got it for 50rs with 100 off coupon.. :p
BTW - the headfones are 2 yrs old :p
ordered eBay India: USB Sound Card 2.0 Audio Input / Output Sound Card (item 390269250352 end time 11-Dec-2010 14:50:00 IST) :D
PERFORMANCE DIFFERENCE
Transcend Pend Drive "File Benchmark"
Directly plugged to m/b USB port & Internal Card Reader (negligible difference)
Plugged into chinese make 4 Port USB Hub.
I'm in need of a good quality/performance USB Hub, pls recommend under Rs.500
Currently i own this -
I want a HUB similar to that, i.e. all USB Ports facing front.
can you send me the driver download link :)
Just today only I got the USB audio, but the dame thing didnt come with a CD, so Windows 7 installed generic drivers.
there are no options for the said 5.1 virtual surround, equalizer ...
It very loud at just 1 to 5 volume level (out of 100).
tried installing two different drivers, but it doesnt install, keeps saying - "Please plug-in COMODOW USB audio" :\
product website - ::COMODOW::
alternate driver page - USB 3D Sound PD552 driver - Drivers
