Suggest a rig within 50k max.
The Knight
Knight is coming
I want to buy some stuff.
But please excluded monitor,cabinet,keyboard,mice,speaker because I have those.
Suggest a mobo,cpu,2x2 GB ram kit,GFX crd,smps.
i5 760 - ------------------------------------------------------------9.8k
Gigabyte GA-P55-US3L --------------------------------------------- 6.3k
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 - 6.2k
seasonic 750 - ------------------------------------------------------6.5k
Msi GeForce GTX570-------------------------------------------------21k
total 49.8k
or
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz-----------------10.2k
ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX---------------------------8.7k
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM - -----------6.2k or
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3DDR3 1600-----------------2.9
seasonic 750 ------------------------------------------------------- 6.5k
total 52k
total 49k if u opt for the other ram instead of denominator
total 49.8k
or
total 52k
I'll advocate OP waits for some time let BullDozer scores hit us and then depending on supply and pricing go in for the sweetest kill, I'm not saying what you've suggested is bad, but to be fair almost both the RIGS have reached their respective EoL -- and the AMD Hexas are not good for gaming http://www.anandtech.com/bench/CPU/50 \ http://www.anandtech.com/bench/Product/146?vs=191 + please do not suggest MSI boards due to following reason -- read post by The Sorcerer http://www.techenclave.com/cpu-mobo-corner/need-help-buying-processor-motherboard-under-183565-3.html#post1728227
You know what i think u shud delay ur purchase a bit coz its not the right time to purchase a computer... If u wanna burn ur money and if u wanna buy whatever u think is right then go ahead...
Even if BullDozer doesn't directly impact Sandy-Bridge prices, the price:performance bar has always gone to AMD since the Phenom II series was released and overall the reports are highly optimistic that BullDozer will perform at par with Sandy-Bridge, while priced more strategically. I suggested OP to hold his horses instead of jumping into the fray and regretting the decision later -- have my fingers crossed as I too want Sandy-Bridge to get completely thumped (more like my vendetta towards Intel :ashamed: ).
^BUT I SUGGESTED ASUS OR GIGABYTE BORD NA .EVEN THE MSI CARD R BAD????
SUGGESTED X6 AS ITS FUTURE PROOF NA??
AND ANY IDEA WHEN BullDozer WILL ARRIVE AND ABOUT ITS PRICING
1. Core i7 2500K for gaming
2. HD6950 2GB bang (hole) and buck
June 8th world launch. End of June maybe in India. Pricing will be competitive, as AMD has always been
I did not say your configurations were bad, the rigs you mentioned are EoL -- End Of Life, LGA 1156 has been supplanted by the LGA 1155 a.k.a. Sandy-Bridge and on AMD front BullDozer is coming to the scene with socket AM3+, but in true AMD style AM3+ CPUs's compatible with previous generation AM3 boards (rumors abound).
Watch out Intel AMD is BAACCCKKKK...
