Desert Rose
Well...the story goes like this...
I have a cable internet at home.. and recently..had problems while connecting to internet.. so I thout may be there is some problems with network connections ..ans so went on format and reinstall xp again..
after installing Xp, it would work fine for the first time that i l;ogged on..but after installing few other s/w and restarting...again tht problem popped up saying" Connot contact Server" ( the connection worked fine on my bro's comp)
...And so i decided to install all s/w one by one and check if it connects to internet ..and found out tht its because of Kaspersky 2006 beta that i am unable to connect..I uninstalled it and bingo! ..the problem was gone!.. ( tht stupid connection works fine on my bro's pc even with anti-virus installed )
Now..the problem is ...my PC is full of trojan, svchost.exe, etc etc.. have an adware installed but still.. i'll have to restart cos a messg pops up every now and then saying" System will restart within 59 seconds"...
Why is this happening? :huh:
