My requirements are a bit different than others.
Purpose: Running 3-4 virtual machines as servers.
I am trying to build a simulated prod environment as in large corps, which means running Directory servers, domain controllers, Database and Application servers
Requirements:
CPU: capable of running atleast 4 virtual machines simultaneously
RAM: Atleast 16 GB
Motherboard: One that supports above cpu/ram config
Cabinet: any cabinet that can support the above config and provide decent airflow
What is your budget?
30K
None
Which hardware will you be keeping (component name - component brand and model).
None
Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
CPU -Any which is capable enough to run 4 virtual machines simultaneously
RAM -- any good brand 16GB minimum
HDD -- any with capacity of alteast 2 TB
SMPS -- please suggest
Cabinet -- any decent cabinet
Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
N/A
Where will you buy this hardware? (Online/City/TE Dealer)
Hyderabad (CTC, Most probably dealer named Shewta)
Would you consider buying a second hand hardware from the TE market
Nope, not at all
What is your intended use for this PC/hardware
Software development
Prefers AMD
N/A
N/A
No Way
Win 7
Note:
I already have a 7700 Graphics card which I will be using to output HDMI to my 40Inch LCD TV
Requirements:
RAM: Atleast 16 GB
30K
None
None
N/A
Nope, not at all
Prefers AMD
N/A
N/A
No Way
Win 7
Note:
