Blade_Runner
Random Technical Support Problem/Solution Generator
When you're working on your mom's or your boss's computer, sometimes you just don't know what caused problem or how to fix it. However, you don't want to tell them that. This generator will give you a cause and solution to the problem, so when the problem fixes itself when you reboot you'll sound smart.
Go here
:rofl: :rofl: :rofl:
Go here
Problem: Someone connected the cable to your monitor incorrectly. That will cause your system to bid on Ebay auctions if we don't fix it.
Solution: You're going to have to reboot your network card, if you want it to work.
Problem: Looks like you got infected by the Backdoor.you_are_a_moron virus, from a rogue Logo script installed by Kevin Mitnick.
Solution: You won't need this wretched computer any more, because you're being fired for double-clicking.
