Budget 41-50k Need PC for Multimedia and Animation Student
Hi.. I'm Looking to buy PC for my sister. She is a Multimedia and animation student. She is already using a laptop. But it is not handling animations and video rendering. So, looking to buy a PC for her. I'm not sure about the budget. The software she uses at present are autodesk Maya, Adobe after affects, blender and photoshop. Please suggest a PC for her requirements. Thanks
  1. What is your budget?
    • 50K-60k
    • NA
    • NA
    • No preference
    • Yes, This will be final configuration
    • Chennai
    • Open to online purchase
  7. What is your intended use for this PC/hardware
    • Animation and Video editing
  8. Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
    • No preference
  9. If you will be playing games then which type of games will you be playing?
    • NA
  10. What is your preferred monitor resolution for gaming and normal usage
    1. Desktop - 1440x900
  11. Are you looking to overclock?
    • No
  12. Which operating system do you intend to use with this configuration?
    • Windows 11 64 bit
Just for your reference, I have had Intel i5 - 2nd Generation PC with 16GB DDR3 RAM but it won't able to run/load Photoshop & BlueStack. At that time I add basic entry-level GPU and all starts working OK.
I would suggest looking at the Recommended (not Minimum) System Requirements for each of those Softwares first. They should be documented on their sites.
Out of all select the one with the highest requirements; that will be your starting point.
Also Pugetsystems do a great job of suggesting hardware for content creation based on specific workloads -
www.pugetsystems.com/solutions/content-creation-workstations
Click on the Software platform and then click on Hardware Recommendations. Eg. for Blender -
They do extensive benchmarking for content creation so I would trust their reco.
But you will need to factor in your budget.
Thanks all for the suggestions.. @OMEGA44-XT Please advice which of the below 2 configuration I should go for.
ProcessorIntel i5-14500 Processor
22865​
MotherboardMSI PRO B760M-A WIFI DDR4 Intel Motherboard
14300​
Power SupplyDeepcool PM650D Non-Modular 80 PLUS Gold Power Supply
4850​
CabinetGALAX PC Case (REV-05) Revolution 05 Black
3800​
Memory (RAM)GSkill Aegis 16Gb (16Gbx1) Ddr4 3200MHz Desktop Ram (F4-3200C16S-16GIS)
3000​
Solid State Disk (SSD)Western Digital Blue SN580 1TB NVMe Internal SSD (WDS100T3B0E)
6080​
CPU CoolerDeepCool AG620 ARGB Dual-Tower 120mm CPU Cooler (R-AG620-BKANMN-G-1)
3850​
58745
ProcessorAmd Ryzen 5 7600 Gaming Desktop Processor (100-100001015BOX)
18680​
MotherboardGigabyte B650 EAGLE AX AM5 ATX Motherboard
17680​
4850​
3800​
Memory (RAM)G.Skill Ripjaws S5 32GB (16GBx2) DDR5 6000MHz CL30 Black Gaming Desktop RAM F5-6000J3040F16GX2-RS5K
10760​
6080​
CPU CoolerDeepCool AG400 LED Single Tower 120mm CPU Cooler (R-AG400-BKLNMC-G-1)
1799​
63649
Also please suggest a good basic graphics card to add to this config(preferably not used cards). Will add graphics card if there is any rendering delays.
Thanks once again guys
22865​
14300​
4850​
3800​
3000​
6080​
3850​
58745
18680​
17680​
4850​
3800​
10760​
6080​
1799​
63649
The AM5 one. LGA 1700 is a dead platform. The 7600 isn't too far off in multicore performance, has a better integrated GPU, is more efficient, and gives you an upgrade path.
22865​
14300​
4850​
3800​
3000​
6080​
3850​
58745
18680​
17680​
4850​
3800​
10760​
6080​
1799​
63649
The i5 14500 is noticeably more powerful, heck R7 7700 doesn't get a win over it in all productivity benchmarks. Someone not tech savvy will likely not care about platform longevity & prefer the extra performance instead. Hence I recommended i5 14500 over R5 7600. If it was R7 7700 vs i5 14500, I will recommend R7 7700.
Buy RTX 3060 12GB later on for 25k or lower if GPU is really required, else get a used card for cheap.
Agree with @OMEGA44-XT. 14500 has completely toppled the mid range CPU segment. For productivity workloads, it's the best in it's class. That being said, if you plan on using the setup for rendering purposes without a dedicated GPU, you're better off choosing the AMD build. The Radeon graphics perform so much better that Intel's UHD 770. In any case, if you're gonna go with the Intel build, don't get 1x 16GB RAM, instead get 2x 8GB RAM for dual channel benefits. Also, if possible, try and get a used GPU (at the very least, an rx580 ~ 6.5k) because it's pure pain to render stuff without a GPU.
I will recommend 1x16GB RAM now & buying 2nd 16GB RAM stick later. This leaves room for upgrade to 64GB RAM if needed, considering the rig is for productivity, not gaming at all. Dual channel doesn't help productivity stuff noticeably to consider 2x8GB.
