Hey guys,
So here's the drift. I got the following i7 config:
1. i7 920 processor
2. GIGABYTE UD5 board
3. 6GB G-SKILL DDR3 1600 MHz RAM
4. Corsair TX750W PSU
5. ATi HD4850 graphics card
6. 1 160 GB SATA2 HDD at 7200 rpm
7. 1 80 GB SEAGATE IDE HDD at 7200 rpm
8. 1 LG DVD - RW
I have a Zebronics DRACULA cabinet. It has the following for air circulation. 1 120mm fan at the rear for intake, 1 80 mm fan at the front - intake, 1 80 - mm fan at top for exhaust, 2 80 mm fan at sides for exhaust. I assembled the PC on this cabinet. I have a tube of AS5 and used it for the processor.
The current cabinet temperaure consistently stays at 40 - 45 degrees C. From the BIOS I am able to get the following: System temperature - 52 degrees C, Processor temperature - 44 degrees C, MCH temperature - 54 degrees C. All temperatures were during idle
Need help to decide on the following:
1. Are the above temperature values normal?
2. I might overclock, but not immediately but after a few months. Is this cabinet sufficient? As of now I really had trouble managing the cables although I managed to tuck them here and there to make it clutter free
3. Which is more of a priority, an aftermarket cooler for the CPU or a new cabinet?
4. As of now I have enough cooling fans to fix in the cabinet. So can u guys suggest me a good cabinet that is upto the job. No frills needed, am not for showing off. Anything that satisfies the purpose and does the job well will do. And please suggest something with a decent price tag, not something that will cost 10 - 15K!!!
5. Can this cabinet be used as a stop gap till I get a new cabinet?
After lots of searching around a few of the following cabinets seem to be good choices:
1. Antec 900
2. CM 690
3. CM Gladiator 600
4. CM Centurion 590
The CM cabbies cost ~5K and are good choices. Can u guys suggest some other models from competitive brands as well, probably ANTEC(cos going by the looks of it the Antec 900, 1200, 902 etc should cost upwards of 8K!!) ? And will these cabbys interfere with after-market CPU coolers, say the CM v8 etc?
And a few after market CPU cooler suggestions are also required.
P.S: Please do tell me where to get the respective cabinet/CPU cooler from(shops at Chennai/Bangalore or TE dealers)
1. i7 920 processor
8. 1 LG DVD - RW
1. Antec 900
2. CM 690
3. CM Gladiator 600
4. CM Centurion 590
