Audio need IEM help.. <1.5k
I need a good IEM for daily use.. Budget is 1.5k max.. can order it from US also.. need your help guys.. Im not that into booming bass.. but I need good mids as I mostly listen to softer stuff
The choices I boiled down to are
Soundmagic ES18- Rs 649(flipkart, amazon.in)
skullcandy ink'd 2- 1100
meelectronics m31- 1300
JVC XX Deep Bass HA-FX1X - 1000
meelectronics m9- 1000
meelectronics m16- 850
all the red are from usa
soundmagic pl21-1169(flipkart)
any others?? please help
Lower the better, on a tight budget
