vidar
Recruit
My Friend is doing Animation from MAAC, he is looking to build a new rig for his animation work, he will be using softwares such as Maaya, Fusion, Mudbox, Nuke, After affect etc. his budget is 40-45k the lower the better.
Q: What is your budget?
A: 40-45k
A: None, He gave his PC to his brother, so currently no PC.
A: WD HDD 500 GB, Mx518 mouse ,Altec lansing 2.1 speakers, Samsung keyboard
CPU - i7 based CPUs Preferred, if there are any other good CPUs for animation please advice.
Motherboard - Should he invest in a Crossfire or SLI mobo?
GPU - Please suggest
Monitor - Full HD
RAM - 1333 or 1667Mhz ??
PSU - Suggest a future proof PSU, he will be adding few HDDs Later.
Cabinet - Mid size
A: No
A: Delhi, Nehru place
A: Yes
A: Animation - 1st priority
Gaming
Browsing
Desktop Processing
Watching HD movies
A: No
A: GTA 4, Crysis 2, SF4 etc
A: Animation - Full HD or at-least HD
Gaming - any
Desktop - any
A: No
A: Windows 7 64 bit
Macintosh - Snow leopard X
If there are AMD CPUs which performs almost equal to i7 at lesser price then he is open to that, also if his work can be done with good efficiency on lower side CPUs then no need to invest in i7 or similar CPUs.
Also he specifically told me to get suggestion whether 1667 mhz rams would make a performance difference to him as compared to 1333mhz rams during his works [rendering and stuff] and i think someone mentioned that some Nvidea cards are made specifically for Animators should he select them or normal Gamings GPUs.
A: 40-45k
Monitor - Full HD
Cabinet - Mid size
A: No
A: Yes
Gaming
Browsing
Desktop Processing
Watching HD movies
A: No
Gaming - any
Desktop - any
A: No
A: Windows 7 64 bit
