xOVErClOcKeRx
Hello Peeps!
I've gt my I7 930 @ 4.2 ghz stable and the max temp it hits is around 70...So now i want to reach da 4.4 ghz mark, but it bsods on startup...Here are my current settings>
Tuning Mode - Extreme OC
AI Overclock Tuner - Manual
OC From CPU Level Up - Disabled
OC From Memory Level Up - Disabled
CPU Ratio Settings - 21
CPU Turbo Power Limit - Disabled
CPU Ratio Setting - 21
C1E Support - Disabled
Hardware Prefetcher - Enabled
Adjacent Cache Line Prefetcher - Enabled
Intel Virtualization Tech - Enabled
CPU TM Function - Disabled
Execute Disabled Bit - Enabled
Intel HT Technology - Disabled
Active Processor Cores - All
A20M - Disabled
Intel Speedstep Tech - Disabled
Intel C-STATE Tech - Disabled
BCLK Frequency - 200
PCIE Fequency - 100
DRAM Frequency - 1603
UCLK Frequency - Auto
QPI Link Data Rate - Auto
Dram Timing Control: Manual
Dram CAS Latency - 6
Dram RAS to CAS Delay - 7
Dram RAS Pretime - 6
Dram RAS ACT Time - 20
CPU Load-Line Calibration - Enabled
CPU Differential Amplitude - Auto
NB OCP - Enabled
DRAM OCP - Enabled
Extreme OV - Disabled
CPU Voltage Control - Absolute VID
CPU Voltage - 1.3500
CPU PLL Voltage - 1.8600
QPI-Dram Voltage - 1.3000
IOH Voltage - 1.2500
IOH PCIE Voltage - 1.6000
ICH Voltage- 1.11341
ICH PCIE voltage - 1.51106
DRAM Bus Voltage - 1.6400
Debug Mode - String
Keyboard TweakIt Control - Disabled
CPU Spread Spectrum - Disabled
PCIE Spectrum - Disabled
CPU Clock Skew - Auto
IOH Clock Skew - Auto
A20M - Disabled
PCIE Fequency - 100
NB OCP - Enabled
DRAM OCP - Enabled
Debug Mode - String
