Hey,
This might seem like a very stupid question to most of you, but I have a Coolermaster Elite 330 and I wanted to take the front of the cabinet off... and have no idea how to do it! Can't find any screws or anything to do this after taking off the side panel and am too scared to try to yank it out.
As far as i remember, its an easy job. there would be plastic tabs/ plucks on the inside that you just need to push to pop the front off. no screws, just plastic | bits.
if confused take a pic from the inside and peeps will point out the bits to be pushed.
edit: no need
just refer the instructions here - see somewhere in the center -
Essentially you have to bend up the tabs that hold the grill work to the frame of the case and then remove the filter in the case of the bay covers. In the case of the front panel you have to remove the panel, lift the tabs and the remove the grill to pull the filter out and PRAY you do not tear it. To say this is a serious design flaw is an understatement.
