Just got hold of a E7300 and my abit IP35E keeps on restarting ....think i need to flash to version 18 but i dont have floppy ....need to do it on my HP 16GB pen drive .
Please tell me step by step how to do it safely. Thanks .
These are the steps [does your motherboard support BIOS flashing from a pen-drive?] --
Hope this helps, Cheerio!
- download the latest BIOS edition that you require;
- format your pen-drive and place this file onto your [now blank] pen-drive;
- change the boot priority in the BIOS of your motherboard to a removable drive;
- restart your system and before it POST's insert your pen-drive;
- if your motherboard sports the feature, it will detect the pen-drive and find the BIOS patch on it, then read the same and apply it;
- after the patching is done it will ask you to reboot, so reboot the system and yank the pen-drive before the system POST's again and you should now be booted onto the OS on your hard-drive.
I fortmat and copied the 5 files in the bios rar and selected the HP drive as first boot option - but mobo says the pendrive doesnt have a OS so cant boot .
Then I doubt that your motherboard supports BIOS flashing from a USB-media. Try using an optical-medium like a CD with the BIOS files on it.
After trying for so many hrs to get the pen drive/dvd to boot - finally solved it - pretty simple actually - used this tool called HP USB boot - it made the pendrive bootable and so the mobo didnt say the drive didnt have OS.
