PC Peripherals Help!! Making my printer wireless
parag1985
71
3
69
38
Hi Friends,
I have a DEN wireless broadband connection and I have a DLINK 2750U ADSL2+ modem lying idle. Now I want to my make newly purchased RICHO SP210 printer wireless. I am able to make it wireless using DLINK at a time but I have to disconnect my DEN modem then only this can happen. So If anybody could help me setting up my modems so that I can use internet and print wireless simultaneously .
Thanks & Regards
Parag
vivek.krishnan
BLR~ZRS-TX-1-MX
Dec 18, 2009
7,863
1,996
303
Ghatkopar, Mumbai
plus.google.com
Budget and readiness to do DIY?
Cheapest would be to get a older raspberry pi and install a wifi dongle, and DIY
Costlier? http://www.ebay.in/itm/232518497412
Anyways, the key word to search is 'wireless print server'[DOUBLEPOST=1508683340][/DOUBLEPOST]Oh, and optionally, you can do it without buying anything new, just get the DEN guy to make your DEN modem in bridge mode, and let the 2750U do the routing
Or, set the 2750U in router mode, WAN as DHCP/Static IP and LAN in a different subnet from what the DEN modem gives.
