Help for pc in 28k for Hd movies + photoshop lyk work + downloading
zktel
1. Q: What is your budget?
1. around 28K
2. Q: What is your existing hardware configuration (component name -component brand and model)
None
3. Q: Which hardware will you be
keeping (component name -
1. None
1. CPU - AMD X4 Phenome II
2. Motherboard - any compatible
motherboard having HDMI port
3. GPU - not required
4. cabinet - Zebronics Bijli
5. HDD - 1TB Seagate
6. Monitor - 24'' Benq G2420 ( want to see TV also so cant compromise )
7. RAM -2 Gb
5. Q: Is this going to be your final
configuration or you would be
adding/upgrading a component in near future. If yes then please mention when and which component
1. Yes,
will upgrade the following after 2-3 years might buy ram , and will add Blue ray drive
6. Q: Where will you buy this
hardware? (Online/City/TE Dealer) 1. Mumbai, Lamington Road
7. Q: Would you consider buying a
second hand hardware from the TE market
1. yes
1. Gaming - Lightly (sum tym)
2. Browsing
3. Desktop Processing
4. Download rig, 24x7 operation 5. Watching FULL HD movies
9. Q: Do you have any brand
preference or dislike? Please name
them and the reason for your
preference/dislike.
1. NO not at all
10. Q: If you will be playing games
then which type of games will you be playing?
1 No Plan of playing games
11. Q: What is your preferred monitor resolution for gaming and normal usage
Not Applicable
1. No
1. Windows 7 32 bit
2. Windows Xp
I cant compromise on Monitor as i want to watch tv also on it
I have a tight budget of 28k please help me out..................
Please edit the post a bit. Its very illegible to read.
Whats the budget? 20k or 28k? First line says 20k and the title and last line says 28k.
Components Description Price (INR)
Processor AMD AthlonII X4 640 4500
Motherboard Gigabyte GA-880GM-UD2H 4000
RAM Corsair 2*2GB DDRIII 1333MHz VS2GB1333D3 G 2100
HDD 500GB Seagate 7200.12 1750
GPU HD4250 IGP -
Monitor Benq G2420HD 11250
Cabinet CM Elite 310 1500
PSU/SMPS Gigabyte Super 460 2000
Key Board Logitech SET - Optical Blk Mouse+ MMKB 700
Mouse NA -
ODD L.G./Samsung OEM SATA DVD-Writer 850
Speakers Altec Lansing 2.1 BXR1121 950
Total 28600
This would make a much better and balanced rig. You dont need a PhenomII X6 unless you are a Pro. If you are a Pro then up the budget and go for it.
zktel said:
Thanks for the help
but wat about AMD phenome IIX4 955
both AMD athlon X4 n Phenome are same or wat
The PhenomII X4 has L3 Cache which the AthlonII X4 lacks. The L3 helps in slightly better gaming performance. So not much use for you.
Plus the Athlon II X4 consumes lesser power.
pls tel me
Which monitor is better BenQ G2420 or Samsung PX2370 Led
I m getng both in good deal
Almost at a same rate
Better buy is the BenQ G2420 haven't heard about the Samsung PX2320. Can't even find it on the Samsung site, closest match Samsung PX2370 -- The most comfortable viewing experience for you - PX2370 - Desktop Monitior - Monitor | SAMSUNG.
For the BenQ G2420 -- http://www.techenclave.com/reviews-and-previews/benq-g2420-quick-review-150074.html a good review from a fellow TE member :). From the BenQ site -- BenQ India | Products - LCD MonitorsScreen Size - 24" & up - G2420HD
A similar thread from Tom'sHardware -- Samsung px2370 or benq g2420 hd? - Graphics-Cards - Graphic-Displays.
Hope this helps bruv.
Some TE members have BenQ G2420 and they have given +ve feedbacks. Not sure about the Sammy monitor. Wait for user opinion or google a bit for user opinions.
