31-12-2004
abhi182
Full Member Join Date: Oct 2004
owww....removing DDO is an extremely painful process...
See, SOme of the older BIOSes (esp Ambios) could not detect Drives over 32 GB ...
one way to handle this problem is to flash upgrade the BIOS so that it can detect 32GB+ hdd's
However, a more convenient but complicated way was to set the HDD jumpers to 32GB clip mode and install DDO ...DDO is a low level driver that kicks in as soon as ur HDD spins up...By setting the jumpers to 32GB clip, ur HDD shows up as 32 GB to the BIOS...Howeevr, when th ePC starts booting, the DDO kicks into action and maps the full capacity of the HDD to show up in the OS.....
So far so good....the problem starts when u want to upgrade/change OS etc. as putting in DDO is easy but removing is far from easy....
Since u say u've upgraded ur m/c, i am assuming u've got a new Motherboard+proc therefore ur new mobo should be able to detct the full 40GB...
You have two methods that you can follow:
I- Easier, but existing data will be lost
II- More complicated but you may (not necessarily) be able to retain existing data
I:
1- The difficult part would be salvaging the existing data on your HDD....since the existing data can only be accessed if the DDO driver is riunning so you'll need to hook your HDD to a machine that has booted on a HDD with DDO on it....If you can manage to getby without the existing data, well & fine..proceed to step 2
2- Remove the 32GB clip jumper settings and set your HDD to Master
3- Get a bootable CD for win98 (I believe winXP cannot be installed directly via CD boot...I may be wrong there though)
4_ Set the BIOS to boot from CD and start the Win98 setup...choose custom setup and Format you HDD (all partitions) to FAT32....unfortunately, some of your the HDD sectors may not be salvageable
5- Install win98
6- Install winXP over win98
II:
1- Get the Disk Manager utility from Seagate (not samsung), download the ISO file image on a friend's PC and burnn a bootable CD (U can create a start up floppy disk for the Seagate Disk manager but since u say that u don't have a FDD so...)
2- Boot using this CD/Floppy..The disk manager will automatically detect your HDD/s
3- Choose the maintenance options and select your samsung HDD...atthis point, you'll get a warning tht this utility is sp. meant for Seagate devices only and using this on a non-seagate storage devic may cause loss of data/device....Don't worry bout the warning though
4- Within maintenance options, you'll get an option to remove DDO...Follow the on screen steps to remove the DDO from your HDD.....
5- During the process, Seagate disk manager will tell you if the data on your existing HDD can be salvaged or not...I was able to retain most (not all) of my data
6- Once DDO is gone, set the HDDas master and install winXP...
Hope this helps
