Corsair Carbide 300R up for sale. It's just over two and a half years old and has dust and signs of wear. But performance is good and everything works perfectly. The case came with 1x140mm and 1x120mm fans. 140mm still there, replaced the 120mm with a better NZXT fan. In addition, there's also a Cooler Master 120mm 2000 RPM Red LED fan - I believe the model is SickleFlow. (For this picture I have taken it out, but usually it's fit to the rear.)
As you can see from the picture of the tool kit, many screws are missing, but I'm sure that won't be a big issue. Apart from that I think everything is present and correct.
Mumbai buyers only.
Mumbai buyers only.
