:huh: hye friends
whensoever there is a problem i always turn up for help to TE, n i go it
this time too u Homies provided me the bets of the suggestions - pro n cons.
Thanks a lot for that stop by for a noobe.:rofl: :clap: :cool2: hyeah:
This problem starts here, in order to play the games i needed a GPU, n i ended up buying MSi 9800gt, then i conditions PUSHED ME to buy a CM Real Power Pro 460 - in order to run the GPU,
i was using a stock smps earlier - n i was able to download 4-5 Gb daily from my 500c bsnl plan. now after switiching to CM Real Power Pro 460 n the card , my computer gets reebooted even at a small flicker of mains, earlier it was not so - flickers did't affected me - i used to download all night long without a boot up.
i thought that it might be my old 600va microtek heritage ups , that is not able to handle the new loads , so i bought 1000va double battery ups - it claims to protect from power fluctuation in range of 130-300 volts.
i changed it for 10 hrs as said, before the first use but the condition is still the same, my unit boots up every 10 - 15 mins, even i am using a logitech 5kv power fluctuation protecter from last 3 years n got a 1400 va sucam ups wala inverter also. but it's of no use with the new CM Real Power Pro 460.
i am stuck man:huh: - what should i do..........
n one more thing as u guys suggested , my procy (p4 3.0 intel - oc'd to 3.5Ghz,) may bottleneck the card. as i am playing either racegrid or ,Assassin's Creed - the games don't run smooth - goes kind of slow motion even if i takes the grafix to 1024*768 . do i need to upgrade the proccy or is there any other way out............plz suggest
Thanks a ton in advance.......
