Gryph0n
Just bought a Xonar DX from vercetti :clap:.
The card is working fine. However I'm facing an issue with the front panel jack sensing.
When I insert my head-phones, the soundcard doesn't auto-detect the jack. The soundcard pretends nothing has happened, and continues to output to the back-panel speakers . I don't even get any output on the headphones. I have to go the Xonar "Audio Center" and set my "Analog Out" to "FP Headphones", which mutes the speakers and outputs on the headphones.
Is this a known issue with the Xonar DX soundcards, or is there some setting I've missed out?
My cabby has 2 connectors for the front-panel : HD-Audio and AC'97. The soundcard is hooked to the "HD-Audio" connector currently. I'm running on WinXP with SP3 (32 bit).
My onboard soundcard could auto-sense the front panel jack, and would automatically mute the speakers when headphones were plugged into the FP. Why can't a higher end card like the Xonar DX do the same :huh:?
I did google around and found the below post complaining about no jack sensing in Vista, but said it was due to a conflict with the OS and drivers. Is there a conflict in XP too, or is it some hardware limitation of the soundcard?
http://www.avsforum.com/avs-vb/showthread.php?t=1017372
Since everyone here seems to either have or recommend the DX, can someone please post if they are able to get auto jack sensing on the FP?
