BullettuPaandi
General :
Budget -
What is your budget? Mention Locality/Currency & Price Range.
(e.g.) INR 30k-50k.New or Used? Online or in-store?
(e.g.) New. Online.
Brand -
Do you have any brand preference or dislikes? Please name them.
(e.g.) Don't want a <Manufacturer> phone because of <Reason> (to let members know what you're trying to avoid).
Usage -
What is your intended use?
(e.g.) Casual - Calls, texts & Browsing (or) Camera focused (or) Gaming focused (or) All-rounder etc.What is your expected battery backup?
(e.g.) A full day of use with 5+ hours of screen-on time.How long are you intending to use this phone?
(e.g.) Should run fine for 3+ years.
Connectivity -
What is your preferred network?
(i.e.) 4G (or) 5G etc.What is the number of connections required?
(i.e.) Single SIM (or) Dual SIM. eSIM required (or) nice-to-have.
Platform :
Operating System (OS) -
Do you have any OS preference?
(i.e.) Android or iOS.
RAM & Storage -
How much RAM and Storage do you want?
(e.g.) Minimum 12GB RAM & 256GB Storage (or) Should be able to handle <number of apps> in the background & more than <your current storage>.Do you want a memory card slot?
(e.g.) No (or) Yes, up to 1TB. A Hybrid slot is fine; Dedicated slot would be better.
Processing power -
If you have an idea of how much processing power you'd need mention here, else feel free to ignore.
(e.g.) Better than SD870 (or) Better than <current(or)any smartphone>.
Display :
What is your preferred display size, type, resolution and refresh rate?
(e.g.) Compact, AMOLED, FHD, 120Hz (or) Better than <current(or)any smartphone>.Mention any specific requirements here.
(e.g.) Don't want a curved display; Should be LTPO, HDR10+ etc.
Miscellaneous :
Any other requirements?
(e.g.) Need 3.5mm jack, WiFi 6 or above, Bluetooth 5.3 support, USB C 3.2, Infrared sensor, Metal frame, etc.If you have already considered a phone, then please mention.
(e.g.) OnePlus 11, Samsung S23 Ultra, Xiaomi 13, etc.If any requirement takes a higher priority than other, mention here.
(e.g.) Build quality > 3.5mm jack > LTPOFor your consideration, @Crazy_Eddy . Suggestions for edit welcomed.If someone wants to update the template for 2023, I can sticky their post
