Number crunching rig specs for cae, fea and optimization solvers
iamrahul
I need help in buying/building a new PC. My budget and requirements are as follows:
Budget: Rs 30-35k
Existing hardware setup: Q6600,2GB DDR2 800,CORSAIR 450 PSU,VIEWSONIC 19'LCD.,MOBO-CRASHED
Components from the existing setup that you intend to keep: PSU &MONITOR
Components that you have in mind for your new PC: AS PER YOUR OBSERVATIONS AND KIND SUGGESTIONS
Plans to upgrade in the future: NOT IN COUPLE OF YEARS
Places from where you will buy components along with your location: KOLKATA
Intended use of the PC : STRICTLY MATHEMATICAL NUMBER CRUNCHING AS IN NEURAL NETS AND GA BASED OPTIMIZATION ROUTINES ON LARGE DATA SETS, CAE ANALYSIS LIKE ANSYS ,FINITE ELEMENT ANALYSIS SOLVERS, -- I WILL NOT BE DOING ANY RENDERING,CAD OR 3D MODELLING WORK....AND STRICTLY NO NO GAMING
Brand preferences:NONE
Monitor resolution and size:NOT REQD
Will you be overclocking your setup?: STRICTLY NONE WHATSOEVER
Which OS will you use?: WINDOWS
THANKING ALL OF YOU
I aint expert in no.crunching.
I would suggest NVIDIA CUDA system if your software supports CUDA.
Processor :any non K core I7 would do.
I suggest against K series as you dont plan to get overcloked.
