we are using a mtnl internet i have connected 3 computers using same internet in 2 computers it is showing 100 mbps and on one computer it is showing 10 mbps we have same colour Coding give me some suggestions why it is happening
1. The make and speed of the lan card of the machine that is showing 10mbps. If its old maybe that is a culprit.
2. Swap the lan cables between machines that show 100 and 10 mbps and see if it makes any difference. Maybe the cable or the lan port on the switch might be faulty.
3. If that doesn't work try setting the lan card speed at 100mbps full duplex instead of auto sense, and see if that works.
