Guyz i need ur Help.
I am using Q6600 Kentsfield @ 2.4Ghz.
4 GB DDR3 XMS3 1600Mhz.
MSI 5770 Hawk 1GB.
Antec 900 1st Gen. (old)
Gigabyte EP45-UD3LR mobo
CM Extreme Power Duo 600 W.
Win 7 64 bit
i wanna Overclock My pc to a Minimum 3.2 Ghz, I am using Stock cooler.
while typing this temps of cores r attached to the post.
Living in Amritsar Punjab , Climate goes to 50 degrees in Summers.
PLZ suggest which cooler and Thermal [attachment=7902:14105.attach]Paste should i use ?
Should i use a fan cooler or a water cooler. ???
The software i got along the MOBO is easy tune 6 , i have used it to OC my CPU a few times, temps go upto 50 to 68 degree while rendering Videos on 3ds MAX.
PLZ PLZ help me . :huh:
Thanking u all
MSI 5770 Hawk 1GB.
Win 7 64 bit
Thanking u all
