Hi,
I am building a grow room for hydroponics and was thinking of building an insulated room .
Room will probably be built by using cement boards like Bison Panel. Room will be double walled with Glass Wool or other insulation inserted in between. Same will be done for the roof.
I need to maintain humidity at around 40-50% and temperatures in the 18-25° C range.
Probably don't need an AC unit because temperature over here aren't high but will need heating for the winters.
Initial growing area will be around 250sq ft which will gradually increase to 1000sq ft or even more.
Ventilation is important aspect because of high humidity in rainy months as well as keeping out different fungal spores that are usually air borne and are known to be dangerous for hydroponic systems.
Any advise on what kind of systems I can use will be helpful. I was thinking of buying a basic dehumidifier and an electric heater for the time being and later upgrade to an HVAC unit when the size of the room grows.
