Hello,
Planning to buy a new pc. Upgrading from an old HP laptop. Please provide input on the following list. I am not sure if the following list is optimal.
Thank you.
Questions
Thank you.
Questions
- What is your budget?
- About 130k
- CPU - i5 13600k- 30450/-
- Motherboard - ASRock Z690 Phantom Gaming 4 Motherboard (Intel Socket 1700/12th Generation Core Series CPU/Max 128GB DDR4 5333MHz Memory)- 17300/-
- GPU - Most Probably a used 3080ti(50k budget)
- SSD - Samsung 980 1tb- 8000/-
- RAM - XPG Spectrix D60G 3200mhz 16gb x2- 9300/-
- PSU - Adata XPG Core Reactor 850 Watt SMPS 80 Plus Gold Certification Fully Modular PSU With Active PFC - 8250/-
- Cooler- DEEPCOOL GAMMAXX L240 V2 RGB - 6000/-
- Cabinet- Lian Li Lancool II Mesh RGB Black + Type C- 8600/-
- None
- All
- Final. Will buy a 1440p monitor later.
- Online/Best Price
- Yes
- Gaming
- Browsing
- Desktop Processing
- Not Really
- Elden Ring/DS 3
- 1440p
- Not sure
- Win 11
