Help Needed For Ups
para
Hi Friends
I need to buy UPS for my Rig, which can give 10-20 Mins backup so that I can safely shutdown my system without losing any work or crashing my HDD and other components.
My budget is 1-2.5K.
Here is the configuration:
Proccy: AMD Phenom II 555BE (Now B55)
MOBO: GA-MA-785GMT-USB3
RAM: 6GB DDRIII 1333Mhz RAM (1*2GB Kingston,1*4GB Corsair. Both Value Ram).
GPU: Saphire ATI Readon 4870 512MB
PSU: Corsair VX-450W
Display: Samsung Syncmaster 2233M 21.5" running on 1280*1024
FANs: 2 exhaust FAN (120MM China Made)
OS : WIN7 32bit (Will upgrade 64bit)
Thnx
In lower range-Iball Nirantar 630v-2.5k or more,be aware that if you get this ups,your pc might shut down if power cuts while you're gaming,so for safety reasons it'd better if you go for Apc 650va ups-3.1k,hope this helps.
