channabasanna
Hi All,
I am facing these 2 issues since few days. Suggest what has to be done.
1. Now a days i am facing a lot of BIOS issue in my Maximus Formula mobo. Sometimes the BIOS settings gets changed and the Boot Hard disk priorities gets changed. Yesterday i faced the BIOS issue and when i changed the BIOS settings and started it showed the year as 2099.
I am using 320GB HDD SATA, 160GB SATA Laptop HDD (Windows XP SP3 is in 320GB HDD and Windows 7 Ultimate in Laptop HDD)
2. I am having Sukam home UPS (1400), the problem is when the power goes out and by the time the UPS changes to inverter mode the PC gets restarted, so to avoid this. I even connected my WIPRO UPS (donno exactly whether it is 600 or 500, it is almost 8 years old) to the mains, to which the CPU is connected. Still this issue is happening. (PSU is Corsair TX650 v2 and Television is LG CRT 25" Golden Eye Pride, PC Config is in my signature, all lights are CFL of around 18~20W each (around 18~20 CFL's are there in total))
MODS: If this thread is in a wrong section, please move it to a correct one.
Regards,
Channabasanna S
- What may be the reasons for this, is it the BIOS battery is gone or weak?
- How much would a new battery cost, which brand to go for?
- Should i update the BIOS to latest version?
- Any other issues, which might be causing the issue?
- What might be the reason for this?
- Is it due to the TV being on while the PC is runnning?
- Is it because of the time taken to get the UPS running? (Hardly takes less time to switch to Inverter mode)
- What should be done for this problem?
Regards,
Channabasanna S
