FS: Cabinets CM690 Side Window Cabinet + Accessories
axeman
Ye Olde Systems Breaker
Apr 28, 2009
1,689
245
152
Asleep 1-4
www.torrentleech.org
Item 1:
Coolermaster CM690 Cabinet with Side Window - Original Model with Coolermaster 4-in-3 device module.
Price: Rs. 4500 + shipping.
Notes:
  • The toolfree mechanism for HDD's has gone brittle and has broken up, hence the 4-in-3 device module to hold 3 HDD's easily. If you can get replacement caddys, you can use the 5 slots at the bottom easily.
  • The front power button is loose, and has been fixed with double tape. You may disassemble and fix it or replace it.
  • Case has dust/ rust marks wherever dust got embedded, same is visible in the pics.
  • 2 x 120 mm discrete Coolermaster LED fans included - 1 for front, 1 for side panel.
  • 1 x 120 mm Coolermaster LED fan included with the 4-in-3 device module as well.
    • 140/120mm compatible bottom fan grill has a dust filter.
  • Total of 3 x 120 mm intake fans included at this price.
  • Front 120mm bottom fan has a dust filter.
  • Front 4-in-3 120mm fan has a dust filter.
  • Side 120mm fan in the panel has aftermarket dust filter. (Original has none)
  • All filters are washable.
  • I prefer buyer inspect and pick up at Thane/ Mumbai/ Navi Mumbai.
  • Shipping: Note that it weights about 11 Kg approx. So shipping would be surface only, and not exactly cheap. We can estimate your costs if you share a Pin Code for DTDC Surface.
image005.jpg image006.jpg image009.jpg image010.jpg image011.jpg image012.jpg image013.jpg image014.jpg
Links:
http://www.coolermaster.com/case/case-accessories/4-in-3-device-module/
http://www.coolermaster.com/case/case-accessories/side-panel-cm690/
Item 2:
Sunbeamtech Fan Controller - Chromatic Windmill
See album for more pics, as well as display pic in action. http://i.imgur.com/wyknLKN.jpg
Price: Rs. 600 + shipping.
Note:
May not have all cables.
Fans can be plugged in directly, HDD display needs to be wired to the motherboard via provided cable.
Link: http://insanetek.com/accessories/25-sunbeamtech-chromatic-windmill?showall=1
Item 3: Fans:
Sunbeamtech UV LED Fans
Price:
Rs 300 for the 4 LED fan + shipping
Rs 200 for the 3 LED fan + shipping - Cabinet buyer can get this piece free if wanted, just ask.
Coolermaster 140 mm Fan
Price:
Rs 500 + shipping
Item 4: Cables:
Cables:
4 in 1 SATA cables by Lian Li - Both cables are fully functional.
Open Cable: Rs. 700 + shipping
Packed Cable: Rs 900 + shipping
Link: http://www.lian-li.com/en/dt_portfolio/sata-lt90-4/
More pics online.
Full pics album on Imgur: http://imgur.com/a/S0uw6
