Broke CM V650 (OOW) fan while cleaning. Which 120mm fan to replace the PSU fan ?
mk76
This is a 24x7 running NAS powered by CM V650.
The PSU fan was making noises intermittently. Opened the PSU to clean + lube the fan. Broke the plastic + pcb while drilling hole to expose the the rings. Now looking for a replacement.
This is a CM A series fan with fixed 2500rpm at 0.16A . Unable to figure out which one would be compatible ?
Buy exactly what came out.
If not possible, get NZXT F120P 120MM STATIC PRESSURE FAN or any other equivalent.
The one that was fitted in is A12025-20CB-3BN-F1 fan . CM does not sell spares.
What is required is a fixed RPM ( 2500 or equivalent ) @ 0.16A with a 2 pin JST connector . Fourdot has a similar fan but it runs @0.5A . Have ordered a generic one with current specs @0.25A.
If nothing works will mod the PSU to use a variable RPM fan albeit with a different power source to run it.
