coldfire85
Recruit
For medium range wifi ( aorund 1-2Km ) which antenna is better? 16dbi yagi antenna or 14-16dbi panel antenna(antenna from aliexpress)? wifi adapter is TP-Link WN722N
^^ Huh?
A 802.11 connection will always be duplex
It's just a method of extending your home LANI mean what will it be used for, as a source or a receiver. Like a tower and a mobile ...
Meant to say "half-duplex" right?^^ Huh?
Please enlighten me good sire!It's just a method of extending your home LAN
So if you have a place some distance away from your primary home and intend to extend your home LAN to the other place
Since you getting into semantics, duplex could denote both half-duplex and full duplexMeant to say "half-duplex" right?
Say you have an outhouse some distance away from your house - And there are days when you are supposed to sit there with nothing to do than just twiddling your thumbPlease enlighten me good sire!
For the discussion at hand, it is irrelevant
Now to kill time, you could browse the net or watch some movies lying on your home system
But the outhouse is not close enough for you to run wires or for your wireless router signal to reach there
Thats's where this kind of setup would come handy
And why does the Source/Receiver theory does not apply here ? (which i asked about to OP)
And this is not a one way street- You are transmitting as well as receivingAre you transmitting or receiving ?
Okay I will tell my experience. I build a Yagi-Uda antenna with 18 directors and it worked amazzingly well. I build for extending the range of my WiFi following tutorials on instructables and youtube. So Yagi-Uda is a very cheap solution imho.
If you need any help on that then quote me.
Here's a pic.
Because what you said is this
Haha, my bad then!I meant that in a type of role being played by the antenna, not literally!
