Budget 51-70k Where to buy this parts
Hello Guys where to buy this configuration In calicut?
Is it good?
CPU- Intel i5 4570 3.2 Ghz
GPU-MSI/Gigabyte Gtx 960
Ram-Kingston Hyperx Fury 16 GB ram (blue color). The dual channel versions are not available in India
Motherboard-Gigabyte GA-H97M-D3H Motherboard
PSU- Seasonic s12ii 520w (The best PSU you can get in india in that budget)
Cabinet- Circle CC830
Optical drive-Asus DRW-24D3STBLKGAS DVD Burner Internal Optical Drive
Storage- WD BlueBlack 1TB
My budget is 65 k
1. Can't answer the first one. Need someone from Kerala to know that. Alternatively you can buy it online. The nearest online store which i can think of is www.theitdepot.com its based in Chennai. Their rates are higher than retail stores. You may not find all the products which you want on that site.
2. It depends on your requirements. You should fill out the buying template and edit your post.
  1. What is your budget?
    • 55K
    • CPU - Intel i5 sandy bridge
    • Motherboard - ?
    • GPU - Intel hd 3000
    • RAM - 4 gb ram
    • Monitor - generic pnp
    • PSU - ?
    • Its a toshiba satelite L740
    • A samsung Monitor : Syncmaster 540n
    • A random iball mouse
    • LG Optical drive
    • CPU - Intel i5 4690
    • Motherboard - any compatible motherboard
    • GPU - GTX 960 2gb
    • PSU - any
    • Ram : Any 16 gigs
    • Case: A good one Preferably blue theme
    • HDD : Any 1 tb
    • None
    • Calicut
    • Open to online purchase
    • Maybe
    • Gaming
    • Recording
    • Rendering
    • Ummmm . NO
    • Minecraft with recording at max and mods + shaders
    • Gta 5
  11. What is your preferred monitor resolution for gaming and normal usage : None
    • No
    • Windows 10
Srry guys didnt respond.
I have os so no problem
  • CPU - Intel Core i5 4440 -12500,
  • Motherboard - MSI H97 PC Mate -7000,
  • GPU - Asus Strix GTX 960 2GB OC -15500,
  • PSU - Seasonic S12II 520w -4900,
  • Ram : Kingston HyperX Fury 16GB(8GBx2) 1866Mhz -6600,
  • Case: Corsair SPEC-01 -3500,
  • HDD : WD Caviar Blue 1TB -4000.
  • TOTAL -54,000.
Processor Intel i5 4690 18,000
Motherboard MSI H97 PC Mate 6,500
Memory Kingston HyperX Fury 16 gb 1600MHz 4000 (two separate kits of 8 gigs)
Graphics Card Zotac GTX960 2GB OC (amp) 15,500
Power Supply Antec VP500PC 3,200
Cabinet circle cc830 3,500
Internal Storage WD Caviar Blue 1TB HDD 4,000
Total around 55,00
Also will buying 2 separate sticks of the same thing work like 2 8gigs of kingston blue
