I'm sorry
@TheBluCookie! only difference i see b/w this and the first build is there is a monitor and no cpu cooler+paste.
the build as it was from the first post itself was fine. just gave my 2 cents for some fine tuning and possible availability issues you might face in India.
if you're set on an fx6300 then i recommend you include the cooler master hyper 212 as the cpu can be oc'ed a good amount.
also, avoid pcpartpicker as it will throw up options that are not available in India.
cpu: fx6300 ~7k
cooler: cm hyper 212 ~3k
mobo: Asus m5a78 based board ~3-6k
gpu: radeon r9 280 or 285 or 380 (all three perform roughly the same) ~22-25k (the 280x outperforms all 3 but might not be available and the 380x hasn't been released)
hdd: wd caviar blue 1tb ~4.5k
ram: corsair vengeance/kingston hyper 8gb ~4k
psu: seasonic s12 520w ~5k
kb+ mouse: cm devastator combo ~3k
opt. drive: standard dvd burner ~1k
pci: wifi card ~1-2k
headphones: sennheiser hd201 ~1k
case: anything other than the cheap no-name ones. decent ones start at ~2k onwards.
whatever's left can be blown on the monitor. what's your budget?
