Budget 90k+ Ryzen 2700 Build
Viz
  1. What is your budget?
    • 100K
    • None
    • None
    • CPU - AMD Ryzen 2700x
    • Motherboard - Gigabyte Aorus X470 Ultra Gaming or MSI X470 Gaming Plus Motherboard
    • GPU - GTX 1060
    • PSU - CORSAIR CX650 SMPS?
    • NZXT SOURCE 340 (ATX) Mid Tower Cabinet
    • SAMSUNG 860 EVO 250GB M.2 Internal SSD
    • 1TB Harddisk
    • BENQ GW2480 - 24 INCH
    • Yes, will upgrade
    • RAM - 64GB
    • online purchase
    • No
    • 3D modeling and rendering
    • Never gone with AMD builds, but since the Intel processor pricing is sky rocketing, I am looking for this Ryzen build, but please suggest if i can get an Intel processor that is off same capacity to this build
    • Work PC, so no gaming
    1. Desktop - 1920x1080
    • /No
    • Windows 10 64 bit
Thanks in advance for all your time, appreciate all your help.
Namaste,
About to order these from primeabgb, can someone please confirm if they are compatible?
-Srinivas
Get these instead except replace the RX 570 with Zotac GTX 1060 6GB Mini @ 23k; all are local CTC,Secunderabad prices except some from amazon.
