Exactly... Was getting this connection from Reliance & that's what I was told by the sales rep..dredream said:haha that simple huh
HailStonE said:Call CC & they will disable Login on your a/c directly from their end...
Then it will be an always-on connection...
Yes it will auto log you off once every 24 hrs even if you are downloading stuff or browsing anything.Aman27deep said:So if torrents are running, will it auto turn off too?
l33t_5n1p3r_max said:Get reliance connections at your own risk. Horrible horrible experience with them in the gaming department. Might be okay with the wired connection but steer clear of the wimax.
