User Review Real or Fake ? - Xiaomi 10400 mAh Power Bank
Hey guys,
Firstly to the mods, please move this to the appropriate section. I'm not sure where this one belongs.
Why this thread has gone up is because I recently got 2 Xiaomi 10400mAh Power Banks (XPB for short) from Ebay from the seller AllPhoneUnlock: http://stores.ebay.in/allphoneunlock/
The 1st one is the white model, which I procured from http://www.ebay.in/itm/271499716397?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 for 1100 bucks (using Axis coupon; was listed for 1299).
The 2nd one is a golden one (as the white went was going for crazy prices) from here http://www.ebay.in/itm/281357022775?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 (1300 bucks; same coupon; listed for 1499)
Got the 1st one around a week back and have been using it since. Works wonderfully. The 2nd one came 2 days back and just looking at the packing made me suspicious.
I looked at http://en.miui.com/thread-19104-1-1.html (pointers for figure real vs fake XPBs) and found the following differences (which warrant me to believe that the 2nd one is fake):
(P.S.: Before beginning, BOTH the packing came with Xiaomi stickers, which when scratched, revealed a code, which when checked on the Xiaomi verification website, said BOTH are genuine. However, I'm not convinced, so let's see the following points)
1) Packing: The 1st one i.e. the white/silver XPB came in a SEALED satin-ish paper, which had to be peeled away to reveal the PB. There was no way one could take out the PB without damaging the packing. Again, it was sealed. Moreover, the PB was then sealed inside another white plastic box. So double sealing. And exemplary packing.
The 2nd one i.e. golden XPB came in a cardboard box, UNSEALED. Huge difference in packing. One could just open the box and replace whatever was inside. No seals, no plastic box, nothing. Very strange.
2) Lights/LEDs: Please look at the picture below:
If you notice carefully, the golden one has DARKER LEDs when compared to the white one. There seems to be some translucent covering behind the white one to minimize overglow.
Moreover, when we press the button to see the charging status, things become more clear:
The golden one has light bleeding, whereas
The white ones doesn't !
3) Ports/Paint:
As you can see, the golden PB's micro-USB port is NOT CENTERED, whereas the white one is perfectly centered in the casing (I'm not sure how far the pic can show this, but holding both the PB at eye level show this). Moreover, the golden one's PAINTJOB is CHIPPED at couple of places as marked. The white one is flawless all around.
4) Printing: Another pic:
If you see closely, you'll notice that the golden one has a darker printing as compared to the smoother one on the white PB.
Another pic to show the same:
What do you guys think ? Can you compare your XPBs with the posted pics and see any similarities/differences ? Please chip in. Meanwhile, I'll try to have a word with the seller.[DOUBLEPOST=1406671086][/DOUBLEPOST]Oh, and the reason I'm putting it up (was asked on another forum as how does it matter, sab chinese hain), the difference is mucho. Xiaomi uses LG batteries and Texas Instruments chip to control power on board, making it safer. The cheaper ones using thin wiring and unverified chips which can cause explosions. Check here: http://en.miui.com/thread-19104-1-1.html
Can cause major fire hazard.
@Spacescreamer @piper[DOUBLEPOST=1406674365][/DOUBLEPOST]Just went through this video:
Looks like what I've is genuine. The usb cable is of the right color (and without logo as well). I haven't checked pass through charging. Will do it sometime later.
Might be used, not fake. Can you check the warranty start date on Xiaomi's site?
No. What you do is scratch the code and enter. The site tells you whether it is authentic or not and how many times has the code been checked for. Mine said this was the 1st time it was checked (as it should ideally be).
well if we see the 3rd pic, the black one has a dent on the side and it's casing is not uniform and much thicker than the golden one.
looking at the above pics, one cannot makeout whether it's fake or not. more significant proof is required. Main proof lies in the battery, if one of them is a fake one then in coming days somehow the performance of one will be obviously inferior to the other provided both are used extensively
That's not a dent. That's the TPU case. The actual material of the white one is not visible in the pics !
Update:
The seller (Allphoneunlock) just called. Discussed with him all what I found. He listened patiently. We did discuss that the box scratch code was found genuine on the site. Also he said that the new packing from Xiaomi is the box one (for the colored ones at least). Even he is flabbergasted as to why is Xiaomi supplying the premium colored version without the plastic case while the white comes with one.
Anyway, he agreed on replacing it with another one. No stocks at the moment, so asked me to wait for a week.
Overall, very professional seller. Listens and talks to resolve problems.
OoS, as told by the seller. Many of the Ebay sellers increase price artificially to make sure people don't purchase the item till they get them back in stock.
Chinese Clone from Sure the one you brought
They call this china Oem in Mumbai market
Nah. See the video from Xiaomi, plus the MIUI thread I quoted. And the scratch code checked out, so I guess they are genuine. Anyway, getting it replaced, so not much of an issue.[DOUBLEPOST=1406710508][/DOUBLEPOST]Official pricing of Xiaomi 10400mAh on Flipkart - 999 INR (799 for 5200mAh). Brilliant pricing !
Also Pistons for 999 INR.
I also bought two silver power banks from allphoneunlock, decent guy, both were brand new and are working great and a 100% genuine.[DOUBLEPOST=1406715876][/DOUBLEPOST]@alekhkhanna where did you find the info regarding official pricing for Xiaomi accessories.
It's on Flipkart's site.
PBs: http://www.flipkart.com/mobile-acce...4da0bf41409b&otracker=ts_miAccessories__image
Piston: http://www.flipkart.com/mi-zbw4122i...e42fc1126a10&otracker=ts_miAccessories__image
Cover/Guard: http://www.flipkart.com/mobile-acce...6f17c0b46247&otracker=ts_miAccessories__image
Negative media, bring in more attraction and attention, people researching about it and finally news channels running a big show , saying do you trust the chinese brand? All in all a constructive effort with no loss for the company; a company unheard of previously rises to riches!
And from HK to India ? :/[DOUBLEPOST=1406784454][/DOUBLEPOST]Also update: Checked the pass through charging. Working fine with both the models. Also holding the power button on the battery while charging keeps the LEDs on as long as I'm holding it (the fake one doesn't). Convinced that both are genuine. Yay ! :)
