PC Peripherals PSU to replace my Corsair VX450W ...
PoBoy
My Corsair VX450W bought in Oct 2007 is on its last legs. The same PSU bought by my cousin at the same time just failed. I would like to replace it before it fails.
I just can't find a decent PSU below Rs 5000. Ideally I would like a Seasonic G-360 type PSU :
( http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=313 )
My config is lo-power ( Haswell i3 using integrated graphics, one SSD, one WD Blue ).
Any suggestions ? Seasonic S12II 430 not available anywhere.
Have you looked at the Antec VP550P ?
BTW, what makes you say your current PSU is "on its last legs" - what indications?
It's 10 years. I def don't want a PSU failing when my system is on - it may take a few other components along with it.
Dang. Mine too is around 9 years, currently using it on a new PC. I guess I should switch to the crappy but new vs550 that I got!
Even my psu is like 10 years old now. How do we even test a psu whether its giving enough power over all the cables on full load?
I wonder where we get the Cooler Master Master Watt Lite psu in 500W range here.
Just got the Seasonic S12II620 for 6k. Both 520 and 620 are overpriced online. I did not haggle at all for the 620, could have shaved couple hundred.
