My PC configuration is as follows
Motherboard - Gigabyte GA-E350N with onboard AMD CPU and also onboard AMD Radeon HD 6310
RAM - 8gb DDR3
HDD - WD 1 TB Black 7200 RPM
DVD Writer
Its powered by a Circle Slim SMPS
The issue is, HDD is giving frequent read/write errors. OS is win 8.1 and frequently crashes on start. I did a full surface scan and there are zero bad sectors.
This leads me to think whether the SMPS has not got enough power and hence the HDD is having issues
Can someone advise me on this and if SMPS is the real issue which one should i opt for
RAM - 8gb DDR3
DVD Writer
