marX
Recruit
- What is your budget?
- 20k
- CPU - Intel i5 4440
- Motherboard - Gigabyte B85 D3H
- GPU - ATI 6850 1GB
- RAM - G.Skill Sniper DDR3 1600 mhz 2x4 GB
- Monitor - Dell 22" IPS (1080P)
- PSU - Seasonic G 550.
- Hard Disk: WD Blue 1TB
- Monitor and PSU for sure.
- Rest, I'm open to suggestions.
- Open to suggestions.
- Yes, will upgrade everything after 1 year.
- Dealers in Kerala
- Open to online purchase
- Yes
- Gaming
- Professional CAD/CAM work
- I'm an AMD fan !
- Mordor: Shadow of War
- Gaming - Above 1280x720
- Desktop -1080P
- No
- Windows 10 Pro
- MAC OS (lol)
I'm in a dilemma right now whether to upgrade or not. I want to play the Shadow of War in decent graphics settings but I might move abroad in like 7-8 months. The motherboard, cpu, ram, psu and ram can be shifted to my new place. Also, I would be fully upgrading my PC or buy a next gen console after I get settled in, may be after 1 to 1.5 years from now.
So, what do you guys recommend me to get right now ?
