Budget 0-20k PC for office use
viraj071
  1. What is your budget?
    • 20K-25K
    • CPU - Intel G4560
    • Motherboard - Gigabyte GA-H110M-S2(H OR DS2 ?)
    • GPU - Not required
    • RAM - DDR4 8GB (Any brand with good RMA)
    • Monitor - Not required
    • PSU - Antec BP450
    • Hard-Disk - WD 500 GB
    • Cabinet - MicroATX
  3. Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
    • No
  4. Where will you buy this hardware? (Online/City/TE Dealer)
    • Mumbai ( PrimeABGB ?)
  5. Would you consider buying a second hand hardware from the TE market
    • No
  6. What is your intended use for this PC/hardware
    • Office use. Stability important.
  7. Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
    • Any company that has good RMA
  8. If you will be playing games then which type of games will you be playing?
    • No games.
  9. Are you looking to overclock?
    • No
  10. Which operating system do you intend to use with this configuration?
    • Windows 7 64 bit
    • Need to run DosBox
Seems like you've already picked out your components. That's a good build (if you can find the G4560 anywhere for a decent price). Make sure the board has an updated bios for 7th gen cpus. As for ram, a single 8gb stick of HyperX Fury 2133mhz should do the job. Don't think you can go higher on H110 boards.
I would get a better PSU though. Avoid Corsair's VS series and Antec's BP series. At the very least, go for an Antec VP PSU. But the best option would be to go with a Seasonic 430W unit.
Check this PSU guide - http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
CPU : Intel G4560 5.4k
Mobo: Gigabyte h110m s2 4.1k
RAM : Corsair Vengence 8gb 4.4k
HHD: WD 1 tb blue 3.4k
SMPS: Antec VP550P 3.8k
Cabinet: Circle 820 2.6k
