FS: Networking Network Attached Storage/24x7 Download Machine
mannuel
HI
24 X 7 Download Center with Network Attached Storage Going Very Very Cheap
I will be providing you people with Banana Pro A Single PCB computer with 1Ghz Processor and 1Gb Ram
It Has Sata Connection For Connecting Hard Discs.
SATA Port Gives more Faster Data Transfer Than USB
2 USB Ports Inbuilt Wifi and IR Receiver For Your Remote Control
ITS better than Rasperry PI or any others .
RPI Share chip between Ethernet controller and USB making it Slower Compared to This
IT CAN trans code and STREAM 1080 MKV files to upto 5 Devices Simultaneously via Gigabit Ethernet
I will Give Following Items
One Device
One Case
Power Source which is Very Important
Micro SD Card 8gb With OS installed
Wifi Antenna
Other Than That I will Help You in setting Up the Device Personally( Through Team Viewer) as a NAS
Yes same Only but with Optimum Power Adapter and Cable ( Remember RPi is very selective on this matter).Sata Cable ,8gb Micro SD Card with OS,Free Technical Support
