Need less than 10 inch hdmi input display
Hi
I need a display monitor or tablet less than 10 inch for viewing my cctv... The only requirement is an hdmi input.
I am not sure where to get it and what to buy. Any ideas would be helpful
Thanks in advance
Its quite unusual size. I doubt you get monitors those size. Just get a 15inch monitor for 3k.
Thanks for the reply. However the problem is I want to keep it mobile. Take the monitor with me when I go to shop and then bring it back.
As a result the 15 inch is going to be too big that's why need a smaller monitor or tablet less than 10 inch
for tablet, you can get lenovo yoga tab for its 10 inch screen. Its costly tho.
https://www.amazon.in/Lenovo-Yoga-T...=UTF8&qid=1511755360&sr=8-1&keywords=yoga+tab
better buy a mi pad or nexus 7 in olx/quikr and try to make it work. There are few intex/iball/ chinese tablets in 3k~5k range but I absolutely have no experience with them
hdmi to micro USB cables can work. But I'm not sure tbh.
https://www.amazon.in/dp/B071FB7CTJ/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=cd818f9c-142a-4b42-ad2c-f0421857aaf5&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B00ECYUAAU&pf_rd_m=A1VBAL9TL5WCBF&pf_rd_r=N5N2DQCWJX4QG73EW0HD&pf_rd_r=N5N2DQCWJX4QG73EW0HD&pf_rd_p=cd818f9c-142a-4b42-ad2c-f0421857aaf5
on second thoughts , dont use the above method. Its not 100% reliable according to reviews on net
Btw offtopic but why not keep the monitor in shop at all times?
There is no space only in the shop... That's the problem
You have the USB powered monitors, which will do the trick. But, I think they are 15.6 inches. But portable.
EDIT - Bad Idea, they dont do HDMI or VGA. Look for Raspberry Pi screens instead.
Thank you checked again... Seems with pi screens... I get some half decent options... Any screen you have used before?
