Imran Akhtar
Recruit
Questions
- What is your budget?
- 50K(10k more if needed)
- None(I have 10 years old pc which is not being used)
- None
- CPU - i5 4690K or i7 4790K
- Motherboard - Z97a (or) MSI Z97 Gaming 5 (or) Asus Maximus Vi Hero
- GPU - Gtx 970 or 980 ti (this is optional as I will buy it after 3-4 months)
- PSU - sesonic 700W
- 256 GB SSD
- 2TB (or) 3TB HDD
- cabinet: Corsair 100R
- Ram: 8GB or 16GB(as per the budget)
- water cooling system(later when i buy gpu)
- 22" or 24" monitor
- Yes, will upgrade the following within 6 months
- Hyderabad
- Open to online purchase
- Yes (if parts are purchased with in a year and are in good condition)
- Gaming
- Video Editing
- Photoshop
- maya
- Cinema 4D
- No Pref as long as products are good
- League of Legends
- GTA 5
- Witcher 3
- Battlefield
- Gaming - 1920X1080P
- Desktop - 1920X1080P
- Yes(maybe later)
- Windows 10 most probably
