Is asus gtx750ti OC edition consumes more power than the stock edition?
Also, is it require any extra pci power from psu??then how much power required in rails?
I hv heard the stock edition uses only mobo power.....
you are being nothing but ignorant there. AMD is not run by donkeys.Ah..oh...it is a redeon....got some past bad experiences, also very bad support.....it may hv beaten nvidia 750ti in some games but quite sure there must be many games driver tweks will be needed and ati will not provides it but nvidia does and win the battlefield........
look if u are a nvidia fanboy,why even ask for advice,buy a 750ti.Amd is good, no offence but hey, it is my past experience though i m not actually a nvidia agent....
But after the release of every game nvidia releases revised drivers optimised for that game....but not amd for catalyst....
I used 2 amd gpu*s for nearly 5yrs and then i was a fan but after using nvidia, things have changed.
...look like after selling, nvidia cares much for their customers
Please check☺i never actually wanted buying suggestions rather the technical differences between them....Is asus gtx750ti OC edition consumes more power than the stock edition?
U can push them equally far depending on your heatsink.power draw will be almost same[DOUBLEPOST=1475942802][/DOUBLEPOST]I asked to know the difference between asus 750ti oc dual fan edition and asus 750ti Ph single fan edition.....is i know a little about them......
And that's exactly why I answered your question before itself.Please check☺i never actually wanted buying suggestions rather the technical differences between them....
