Monitors Need a monitor for gaming under 6000
Hi and Welcome to the forum.
Please tell which GPU are you using because that is a major factor in deciding the resolution for the monitor.
Bro what about Dell e1916hv
Specs- 768p , response time - 5ms , viewing angle 178:178 , static contrast ratio- 1000:1 and also priced cheaper than the lg one!
the 750ti will run most games comfortably at 1600x900. you might even be able to supersample to 1080p for some games.
if your planning on upgrading the gpu later then take note that a monitor upgrade will probably be needed to get the most out of it. almost all gpus above the 750 run games at 1080p quite nicely.
hope i haven't confused you :D
