soumyajit92
- What is your budget?
- Max limit 50k.
- none
- none
- CPU - AMD FX 6300
- Motherboard - Gigabyte ga78lmt usb3
- Ram - gskill ripjaws 1600 mhz 2x4gb
- hdd - wd purple 1tb
- gpu - gtx 750 ti
- psu - antec vp550
- cabinet - cooler master n200
- cooler - tx3 evo
- dvd - asus
- mouse+keyb - g400s + logitech wired keyboard
- Wont be upgrading for 2 years at least.
- kolkata
- No
- CS GO
- Everyday usage with moderate level of multitasking.
- No idea on this.
- cs go (serious)
- gta v (casual)
- battlefield 4 {casual)
- 1080p.
- No
- windows 7
should be able to play cs go without any hiccups at 1080p high with 100+ fps. Other than that no serious gaming mostly casual gaming of titles like fifa 15, gta v, bf4 and the upcoming ones. Nothing fancy , should be able to run it at some humble settings.
Other than gaming i need it to be fast for daily usages like photoshop, illustrator, matlab, multitabbed browsing/streaming.
The above mentioned config is coming at around 45-46 and ive around 5k left. So should i get i5 4440 or should i go with gtx 960?
