Does it stops at 80% ?My brand new iPhone 8 Plus which I got from Amazon is not charging up to 100 %. Is this normal? It's just 1 day since I'm using it. And Amazon doesn't have a replacement policy for Apple iPhones. If I take it to the service centre, will they replace it for me?
Format it and charge it again, Also you sure Amazon does not alow replacement on Iphone, Afaik they replace any phone with in 10 days time from delivery.
Just format the phone and drain it till 0% and charge it again should solve the problem if not get in touch with Amazon or the Apple SC.They have an exception for Apple iPhones in their replacement policy. It's clearly mentioned in 'Fulfilled by Amazon'
I'm getting this message while trying to return the phone
How can we resolve it?
Talk to an expert
To replace missing or damaged parts or troubleshoot technical issues, use the contact info below.
See manufacturer contact info"
And yes it stops at 87 % after overnight charging and repeated daytime charging attempts
Any such tool for androidDownload this http://www.3u.com/
Connect your iphone and check battery stats there. You will get better idea about your battery cycles and capacity left.
You can also check capacity from you iphone. Settings > Battery > Battery Health.
I am not aware if any Android utilities are available such as 3U tools.Any such tool for android
This is normal. generally 20-70% charges up faster. 80-100% takes time.My iPhone is charging 80 % to 90% in 30 minutes. Is this normal?
Yes it’s normal. Use the Apple supplied charger.My iPhone is charging 80 % to 90% in 30 minutes. Is this normal?
all phones i guess have hardware auto cutoff to prevent overcharging.May be some apple update have restricted charging only.upto 90 cent so as to prevent damage to battery and extend battery life.
I too have such option in my Android phone where I'm unable to charge it beyond 90 cent unless i disable that specific setting.
Its also software dependent. Only after marshmallow i got that limitation.all phones i guess have hardware auto cutoff to prevent overcharging.
90 % seems to be weird, these can happen on below condition,Its also software dependent. Only after marshmallow i got that limitation.
Hi Carolyn,
I have done it many time, After restaring the phone battery will increase % from 80% to 82% then it will be struck at 82%
One more thing, After that i unplug the phone and drain his battery approx 10 to 20% then plug-in again, Then phone charges complete 100% but charging time duration change as compare normal charge..
If i will not fully drain iphone battery then phone will take normal time of charging and never strick.
I didn’t get solid reason of this issue plz must inform me
