kidrow
Hey all,
So between the Logitech Z323 & the Creative T3300 & the T10, which would you say is best overall?
I initially started with a budget of 1k & was tending to lean towards the Logitech LS21. But then mostly mixed user reviews made me a bit apprehensive & so I decided to up the budget to between 2k-3k. The above mentioned models can be had for around that price point.
At the outset, I'd appreciate if someone can tell me if there is going to be a decent improvement in sound quality from the 1k Logi LS21 to the 3k ones. If not, then I'll save the money of course.
Another similar thread on TE threw up Edifier M1380, C2, Fenda A520/521 & Sony D8/9 in addition to the ones above. But I think they are either unavailable or over the budget.
Music listened to will be from all genres. Decent bass is needed but would forego heart-thumping bass for overall detail & clarity.
Thanks a lot! Cheers.
