iOS Ipad air - battery replacement suggestions
cri_sss
As title suggested, ipad air battery is coming to dying stage.
Don't have apple care as it is few years old, but where i can find in Hyderabad for reliable/replacement battery for Ipad air.
How much does it cost if it is authorized showroom. I found out from you tube its not easy to replace the battery.
Any suggestions. Thanks
Not sure this comes under this forum or market.
The battery can be changed but it will not last long. I had changed the battery for iphone 5 and it lasted only for less than 3 months. It is better to discard the old one or exchange with a new one.
Apple doesn't replace batteries of iPads, instead they replace all the internals attached to it along with the battery. Cost from an official store could range from anywhere from 10-20k.
I would recommend that you either use it as it is or to get the battery replaced by a local repair centre. Hyderabad should have a few
