Private Ryan
Hey guys, i bought an Iball Workhorse cabinet..it looks like a clone of the MAC PRO..hyeah: With my earlier system, i had to keep the side panel open to cool my p4 3.0c ghz ht800 proccy..otherwise the fan rpm wud go beyond 5400 rpm with the cpu hovering around 45C..with the side panel open it wud stay near 39C..
but in the process the system wud gather a lot of dust and worsen the case as the dust wud accumulate on the HSF...
Now with my new system, i want to properly optimize the air flow inside the cabinet so tht i do not have to keep the side panel open..now apart from putting a fan in the front n a fan at teh back panel, what else needs to be done to take care of the air flow..shud i attach fans in the side panel vents?? Wudnt it disturb the flow of air from the front to the back?? Pls help me out..as i am concerned with the heat issue especially since the gfx card will add up to the heat inside..See my sig for my sys specs..
Check this out..
Check this out..
